need to know best way to fix
jvblazn1984@yahoo.com's avatar
jvblazn1984's avatar
jvblazn1984
hey guys here is our new mazda 82 b2000 needs some repair but i need to know the best way to fix this stuff....cab corners and bed and doors???
any info will help thanks again
thanks again
jvblazn1984
anybody??
slammed83mazda's avatar
slammed83mazda
holy shit I just realized your in indiana, im in louisville ky.
Honestly man your best bet is to find another truck and cut the pieces out on it, they dont make much replacement parts for our pre 84 mazdas.
Although I did find a site that makes our: fenders, hood, grille, bumper.
lalunette
Get yourself a MIG or a TIG welder, cut the rust out, and weld new metal in ???
Good luck man!
mazdamandan's avatar
mazdamandan
exactly, make sure to take the box off and take a good look first to see just whats left, then media blast and use acid etch primer/sealer to protect it from then on, unless yer better off replacing it,
you may find doorskins, cab corners are common , but not on mazdas, get a shaping hammer and build yer own parts for that.
Take a good look at the frame, with that kind of rot I would be cautious.
A little wire feed Mig should'nt cost too much I spent 400.00CDN on a lincoln flux core, good for sheet. I need a bigger welder for suspension fabrication now though. Buy a big welder 240v Gas assist if ya can. Check the classifieds.
mazdamandan
Oh if you have compessor get a cut off tool, to cut yer panels , sawzalls have a way of making a mess on large body panels unless ya have a lot of experience with them, the finer the tooth and faster the speed the better. cheaper than buying a compesser
jvblazn1984
yea i have metal work on my nissan i have done a lil bit here and there i plan on stockflooring this one i did a traditional on my hardbody i prolley will just make new ones then
