Tail Light Wiring HELP!
pocket_rocket05@hotmail.com's avatar
devb22's avatar
devb22
Okay,
To make a long story short I need to know how the tail lights hook up to the stock harness?
There is one plug on the main harness to the rear, but 3 bulbs in the lense itself. So could someone take a picture of the rear pigtail setup or a drawing of some sort!
In short I was setup for a skin with LED's, but sent it back and picked up a set of tails that don't have the pigtail setup!
Thanks!
Dev
devb22's avatar
devb22
Bump.....
Dev
hocbj23
I will pull a light or get a schematic tonite and post.Briefly the top lite is a one contact bulb for turn signal.Middle lite is a two contact bulb,and serves as brake lite and rear running lite.Bottom bulb is clear one contact bulb for backup lites.It works off the reverse switch on your tranny.BJ
lalunette
What year is your truck?
I can send you a pic of the wiring diagram from an '86 tech manual, as well as a pic of the actual wires & plug.
Let me know what you need.
devb22's avatar
devb22
'89
That would be awesome!
PM'd
Dev
PB
pimp b2200
try useing a test light or dvom to find brake,turn signal and parking lights.Ground the test light then put the lead in one of the terminals and whatch for the the test light to up and you'll find what youve tested
lalunette
Nice finger no?
I hope this helps.
I know the pic of the wiring diagram isn't the best but my Logitech ClickSmart 510 can't zoom in anymore. I can scan the wiring diagram using my scanner at work.
Let me know
