QUICK QUESTION, NEED HELP ASAP
8
89mazdapimped
I was screwing around on ebay and found these
will they fit on my mazda? let me know guys thanks
sierrax
From the listing that they give the bolt pattern is the same. The center hubs will have to be bored. I would double check the offset before making a bid.
devb22's avatar
devb22
Same here!
Or go to Les Schwab and tell them what you need and if they will fit!
Thats what I did! And it all worked out fine!
Devon
bagdb2200
They have a slightly higher offset than the Infinitis. If we can get the Infinitis to tuck, you can get those to tuck. You might need 4x4 sheetmetal though.
Post was last edited on Apr 24, 2007 06:38. Edited 1 time.
h2omelon(nick)'s avatar
h2omelon(nick)
they will fit but you will need to have the center bore opened up. they will not tuck without modifying the bed sides.
bagdb2200
Yea, just found they're 18x8 with a +31mm offset. So they'll tuck in about 1/4" more than Infinitis do.
red_b2200's avatar
red_b2200
they will fit but they will stick out a little
