removing Front Bumper
blastation
hi fellas,
Trying to remove the front bumper of my 87 mazda b2000, can some one help me and tell me where all the bolt that i got to remove. even better if we got a diagram or picture of where the bolts are at thanks ahead of time for all help, starting to work on my truck now since its starting to cool down, got the bolts of the bed just got to remove the bed but need help to lift it off. but will start posting pics when i do.
Ron
slammedyota91's avatar
slammedyota91
pull the grill off and its pretty clear where the bolts are, frame rails, youll see em..
dropped90(justin)'s avatar
dropped90(justin)
open your hood and look down where your battery box is and where your steering box is. you will see the mounts and bolts.
blastation
ok will try that i have the grill off right now and took a couple of bolts off but seems like its still being held by something on the bottome.
watt's avatar
watt
theres the 2 between the valence and the bumper and then theres the ones next to the steering box and the battery tray... the ends caps are bolt on the backside by in the wheelwell pretty much and then unplug turn signals and its off.
V
v8mazda4ever
there are 4 bolts on the frame that hold the bumper on 2 are on top of the frame and 2 are in front if you get down and look under the bumper where the bracket is you will see them. then on the outer edge there are 2 supports one on each side that need to be undone then your signal lights as well then it should pull straight out and off then you can remove the brackets from the bumper.
blastation
thanks everyone for the help, will try all that tommorrow. If someone gots a pick that would even help more for me.
crazymikey's avatar
crazymikey
it's so straight forward that you wont need pics to figure it out. It's just four 17mm bolts. 1 on each frame rail at the front of the engine bay,under the battery tray on the passenger side and by the steering box on the driver's side. Then,get down,and in the opening of the front valance you will see 2 more bolts,1 on each side near the turn signals. Remove all 4 bolts and unplug the signals and the bumper will pretty much fall off.
blastation
I did it thanks everyone now i got to get me a new bumper, dont know if i want to go with the yota bumper yet or keep my orignal
dropped90(justin)
where are you located at?
