TAKING OFF BED
TAKING OFF BED
dirtymazda90
OK GUYS JUST NEED SOME HELP. IM TAKING OFF THE BED TO FIX THE SENDING UNIT IN THE TANK. BESIDES UN HOOKING THE GAS FILL TUBE AND THE 8 OR 10 BOLTS HOLDING IT ON IS THERE ANYTHING ELSE THAT HAS TO BE UNHOOKED. IM ALSO BRING BED TO BODYSHOP TO GET IT SET UP FOR BAGSAND BIGGER REAR END.
pimpeasyelil's avatar
pimpeasyelil
I just did this last week. You will have the 4 bed bolts on each side. Like you mentioned the gas tank filler. You might have to undo the cable that pops open your gas door if you have one. Of course dont forget your license plate lights and taillights. Follow the wiring and make sure none of it is attached to the bed. After that you should be good to go.
E
dirtymazda90
THANKS
