wheel spacers
fanninator@yahoo.com's avatar
wheel spacers
fanninator's avatar
fanninator
just wonderin, when it comes to the wheel spacers, how do you still have enough studto put your lug on, i heard of like 2.5" and was curious. -bf
midnightmike's avatar
midnightmike
longer wheel studs
dropped90(justin)'s avatar
dropped90(justin)
and some of them use the factory lugnuts to bolt the spacer on and there is lugs recessedin the spacer giving you enough lug to put the wheel on with. sort of like -l_ if that makes any sense.
-justin
fanninator's avatar
fanninator
where can i get longer studs?? -bf
my spacers where only a 1/4 inch ...lugs fit no problem
speedster93b's avatar
speedster93b
those would be known as wheel adapters. one lug pattern that bolts to the hub like a wheel would, with the other set of studs sticking out of the 'spacer' part. you can get same/same or different patterns.
