bed cutting question
quadmasta avatar
quadmasta
I mounted the fuel cell in my truck between the frame rails at the very back. To cut the hole in the bed for the 2 or so inches that'll come through, I'll have to cut through both of the rear channels in the bed. Am I going to have to basically notch that part with some square tubing so it goes over my fuel cell so the bed won't flex?
outkastdawg avatar
outkastdawg
when i done my isuzu i had to cut through mine and i didnt have any problem with th bed flexing. but you could go in and just weld some supports around the area you are cutting out on the bottom of your bed. what would be the best thing to cut a floor and interior walls out with to keep from messiing up the outside of the bed
quadmasta avatar
quadmasta
So you're saying to kind of frame the hole with some square tube before I cut it?
You could use an air saw with a blade that you cut shorter so it won't hit the outside skin. Or a plasma.
outkastdawg avatar
outkastdawg
yeah something like that but i dont think it would flex to bad unless you are mounting the cell to the floor
quadmasta avatar
quadmasta
The cell is strapped into a cradle that's welded between the frame rails.
outkastdawg avatar
outkastdawg
then you really shouldnt have to worry about the bed flexing in my old isuzu the tank was mounted to the bed floor and it didnt flex
quadmasta avatar
quadmasta
I'm worried about the bed flexing because it'd be missing half of the horizontal support.
