tailgate skin?
tailgate skin?
slamedb22
heres the thing my truck already has a welded in steel rollpan was wanderin if i got a tailgate skin will i be able to weld it up to the roll pan or will there be to big of space in between
90-b22dawg [andrew]'s avatar
90-b22dawg [andrew]
depends on where the roll pan came from and where the tail skin is coming from.... your best bet is to get a cali combo.... tailgate skin and roll pan already together and put that on the truck.... link>> 86-93 B-series Grant Kustoms
Post was last edited on Feb 24, 2008 10:37. Edited 4 times.
devb22's avatar
devb22
Yeh def the best bet is to just get a Tailgate Skin/Roll Pan Combo...
GrantKustoms is the shiznit!!
Dev
slamedb22
yea i kno that but im not trin too cut out the rolpan already on it lol
Post was last edited on Feb 24, 2008 11:17. Edited 1 time.
90-b22dawg [andrew]
thats bout the only way to get a clean look and keep all the body lines lined up....
slamedb22
now wat kind of gap would be in between
the rollpan and tail gate skin
droppedmitsu's avatar
droppedmitsu
Probably the same kind of gap that is between the pan and tail gate already or a little smaller.
what dropped said
speedster93b's avatar
speedster93b
it might b worth your time to cut off the old pan and get a new 'cali combo'
have you taken the paint off the welded areas of the pan? there could b rust or just hacked up crap-ass metalwork...
C8
crazy 8ʹs
A cali combo would be the easiest way to do it, but what fun is that? You can always add & remove sheet metal to make you skin fit. Take off your gate and dry fit your skin. See what the gap looks like. If needed add a filler strip on the bottom if your skin. Make the filler a lil bigger then needed, its always easier to remove then to add. I wouldn't advise doing this unless you are comfortable with welding sheet metal & doing body work. It is very easy to warp body panels when welding & grinding.
