pin stripe glue removal???
rollinhard_23@msn.com's avatar
str8scrapinʹ's avatar
str8scrapinʹ
im pulling the stock pin striping off and want to know what the easiest way is.. ive tried a rubber wheel not so good tried a heatgun not so good it all leaves the glue behind i tried acetone to remove it and paint thinner and laquer thinner nothings working anyone know what i can use
devb22's avatar
devb22
I've always used a heat gun then use 3M Adhesive Remover...its NEVER failed!
Looks like this:
Dev
dragginmazda86 (dave)
Plastic razor blades work great. You can get them from most detail shops or paint supply shops.
str8scrapinʹ
awsome thanks for the ideas guys
devb22's avatar
devb22
Yah boy!
Dev
outkastdawg's avatar
outkastdawg
wd40 also works thats what i used to get the glue off my honda after i pulled the vinyl graphics off of it
