Mazda Exterior \  side swing tailgate????????????
Mazda Exterior Mazda Tech
views 1905
replies 16
b22low   +1y
ive seen this mod before but have no idea how to do it? how is it done anyone no????
90-b22dawg [andrew]   +1y
from what i understand... use the stock hinges just relocate to which ever side you want.... reinforce the side you put the hinges on...
b22low   +1y
doesnt the bolt side of the hinge stick out at all???
it does at stock placement.... but you don't have to make it on the move...
b22low   +1y
really ill have to look at it so should i use both hinges or just one? and how should i reinforce it??
def. both hinges.... ive seen some use a piece of tubing inside the light housing on the side where the hinges will mount to and bolt through the tubing.... also seen some with the tubing with bolts and welded...
b22low   +1y
good call so i wont have to cut into my body or anything eh i just got her painted
shouldn't have to cut into her
b22low   +1y
im guna go have a look at it thanks again man.
toddluck   +1y
be careful and make sure it will clear your tail light
