16 inch wheels
matthew217@juno.com's avatar
16 inch wheels
lil big red's avatar
lil big red
I was wondering If 16 inch wheels will fit on std cab b2200 without mods
90-b22dawg [andrew]'s avatar
90-b22dawg [andrew]
depends on the lugpattern and offset also the hub opening size....
lil big red
there from a 2002 Mitsubishi Montero 6 lug
devb22's avatar
devb22
From 1992-Up Montero had a 6 X 139.7 with a low/medium offset...
So needless to say the bolt pattern wont work, and the offset would be rough as well...
For future reference Mazda is 6 X 5.5
Dev <img src="{SMILIES_PATH}/icon_biggrin.gif" alt=":D" title="Very Happy" /><!-- s:D -->
sonikk71's avatar
sonikk71
Dev, Correct me if I am wrong but isn't 6x139.7 the same is 6x5.5? 139.7 divided by 25.4 ( number of mm in an inch) equals 5.5...
crazymikey's avatar
crazymikey
Good catch. That may very well be true.
Anyways,yes,a 16&quot; will fit. You can easily fir up to an 18&quot; rim with a 35 series rubber with no modification. Once you get into anything bigger than a 19&quot; with a static drop,you'll start having clearance issues. You can put 20s on it if you don't lower it,or you can put 20s on it if you cut the shit out of everything.
But I'd recommend a 225/45/16 tire if you go with a 16&quot; rim. That will get you pretty close to the stock overall dimater keeping your speedo correct.
