Page 1 of 4
Mazda Exterior \  need help keep getting tickets
Mazda Exterior Mazda Tech
views 2381
replies 34
following 10
gavin_mosher   +1y
Guys I keep getting pulled over because my tail llights dont work... my break lights both work and both blinkers too.... its just the driving lights dont work.... how can i fix it?
toddluck   +1y
has to be afuse or messed up bulbs,,,,possible a broke ground to the tail lights
gavin_mosher   +1y
where could it be broken at?
toddluck   +1y
start by pulling both tail lights and gt a power tester and see if you have any power getting back there with yor park lights on
gavin_mosher   +1y
my stock brake lights dont even work when i plug them in... ould it be my switch?
toddluck   +1y
ok im confused in your first post you said your break lights and blinkers DID work??????????
gavin_mosher   +1y
Okay my Tail Lights AKA running lights dont work..... but my Brake Lights do when i push the pedal.... i have tried putting my stock tail lights back on but they dont work so i know its not my bulbs.... or my euro tail lights.... idk what the deal is.. i am so fed up with wiring on this truck lol its rediculous
roger26i   +1y
just my sugestion got to a junk yard and get a new tail harness it un plugs at the cab inside the frame beside the gas tank or pull your bed and test all the wires with a ohm meter or test light
gavin_mosher   +1y
so the harness is plugged in near the gas tank? and also how do i pull off my bed is there bolts up top?
roger26i   +1y
no just six bolts two in the rear in the end of the frame two right behind the wheel well and two in front of the wheel well and remove the gas filler neck and its off
