Mazda Exterior \  bubble hood
bubble hood
Mazda Exterior Mazda Tech
views 734
replies 4
fatman   +1y
will the bubble hood clear the 2600 manifold with a body drop?
hocbj23   +1y
the reason that bubble is on the hood of a 2600i is to clear the intake plenum.If u drop the body more than an an inch or two u r going to have clearance problems fo sho.the way to clearance the plenum is to get a stiff piece of aluminum foil,measure it in inch increments,tape it to the highest point on the plenum sticking straight up,then close the hood and see what u have left uncrumpled.that should give u some idea of how much if any of a drop u can do,before clearance is an issue.bj
fatman   +1y
yeah I'm half way through my bodydrop but I got the engine out. my 2600 had a regular hood but i picked the bubble up cheap so i figured it might help a lil' bit
bodied b2600zx (josh)   +1y
damn good idea on how to find how much room you have to play with!!!
crazymikey   +1y
failing that,cut holes or add a cowl
