quick rim question
munkyballz_69@hotmail.com's avatar
quick rim question
808hawaiian's avatar
808hawaiian
what size (mm) is the hub on escalades and what do i have to bore it out to fit? dont reall wanna grind down the tabs but then again some shops i called are tellin me it'll cost $150-200 PER RIM!
thebeaumartin's avatar
thebeaumartin
yeah just grind the tabs bro there is no problems with doing it its eays and cheap
808hawaiian
thing is i wanna try n use the chrome center caps from the mazda rims like how crazymikey had one his dawg
project84 (rahn)'s avatar
project84 (rahn)
Do it yourself!
Good Luck!
808hawaiian
if only i had a router
elbine69's avatar
elbine69
go pickup one at your local home improvement warehouse, or find a neighbor or someone that has one you can borrow
sparage's avatar
sparage
I ground my tabs but you can also use 2 hole saws. Use one the same size as the hole in the wheel for a pilot and slip it into the size of the one you need to bore it.
jax-b-series's avatar
jax-b-series
My roomie had it done to the Titan wheels he put on his hardbody. We saw the youtube router video but went to a hole-in-the-wall machine shop and they did it for $60.00 for all 4 wheels.....oh and I believe widening the inside by 3/8" is sufficient.
