what offset is needed to tuck? i'm running a ranger rear axle and having my hubs redrilled.
I found some with a +35 offset, will they tuck?
speedster93b
i have no idea what will tuck with your ranger axle. it might help some of the others tho if you put your width of the axle....
nytrdr24
my motegi's are 18 x 8's and have a 30mm offset & I have the 4wd
fenders & bed, they tuck about 1/2"-3/4" in, but I'm not body dropped or on bags....So depending on the sheet metal your running, and if you are bagged or b/d'd and aren't running dropped spindles in the front it will be close, with out knowing the width of the rear axle from w.m.s. (wheel mounting surface) to w.m.s. it would be hard to say on the rear....best thing to do would be to measure with the truck on level surface from the w.m.s to the edge of the fenderwell, that will give you an accurate distance for proper offset.
