laying 20's need ideas/advice on clutch master cylinder relo
tlaloc312@comcast.net's avatar
noreservationsaugusta's avatar
who has layed the front end out on 20's. pics of clutch cylinder relocated / moved up / recessed ? Help need ideas.
cl (chris)'s avatar
cl (chris)
Mine is in the stock location its very very tight I am running 225/30/20
cl (chris)'s avatar
cl (chris)
I will take better photos for ya tomorrow
konzern1's avatar
konzern1
nice!!!
tre5
I am relocating mine to the inside. Similar to my buddys toyota. Here is a pic.
You use either an expensive CNC master cylinder with a remote resi. Or do what I am doing, run a master cylinder out of a 95 accord or any other car that has a remote resi. clutch master cylinder.
blackhulk's avatar
blackhulk
hey tre5 do u have more detailed pics and what style and type of clucth...looks pimp thou
speedster93b's avatar
speedster93b
for sure lets see some better pics!
i'll try to post some pics of mine. i guess it'd be called a cantilever clutch setup... where the m/c is mounted on the wheel tub in a sideways fashion, and the pedal activates a linkage that twists ona pivot and pushes the pushrod...
tre5
I will post some pics of mine when I get it going in my build thread. Should be a week or so from now.
KT
kc tony
did you have to do anything other than the 4x4 fenders and cutting the wheelwells to run those wheels and are you using stock or dropped spindles??
speedster93b
here are some in-progress pics. i still have to make the tab for the clutch pedal and the linkage for that. and get a bearing for the pivot to ride on, and weld it of course
