door lock
justafriendtoyou@cox.net's avatar
door lock
seaglass's avatar
seaglass
so i locked the door, come back stick the key in and nothin doesnt unlock, the latch comes up a bit but still not enough to unlock it, anyone know the problem?
lowered_impressions
These mazda lock cylinders sure seem to suck.
90-b22dawg [andrew]'s avatar
90-b22dawg [andrew]
i have a tricky drivers side door cylinder... get you some powdered graphite, should be able to get at automotive parts supply stores
kickinwing
Your going to have to take off you door panel, and start looking around to see if you can find your problem, luckily the locking mechanism on these trucks are fairly simple.
oahub22's avatar
oahub22
my truck is the same way.
i have to play with the door lock to get it open
808hawaiian's avatar
808hawaiian
same happened to me couple days ago...took off my door panel n played wit it...worked fine after
rufus's avatar
rufus
Mine would feel like the lock cylinder was binding up, but I pulled my door panel and put bearing grease on the 3ish connections and my lock is super smooth now.
plumbous blimp's avatar
plumbous blimp
my truck did the same thing once. when i bought it it had two keys, one square and the other circular. i always had the square one cause it looked better, but one day it stopped working and i had to enter through the passenger door. The circular key still works in the driver door though. I think they just get worn down.
Our door cylinders aren't that bad though, when the Mazda 3 came out, there was a problem where a person could pop the locked door open from the outside by punching a certain area on the door. But Mazda recalled the door locks.
