Mazda Exterior \  door problems
door problems
Mazda Exterior Mazda Tech
views 1096
replies 13
following 10
shilaeli huggr (burdaddy)   +1y
anyone elses door not latch when they close it? i shut mine and it bounces back. hafta shut it a couple times to latch.
89slammed   +1y
mine did it when i first got it but the striker bolt was bent so i bought one and now its fine id look at that the see if the door is staying lacthed
toddluck   +1y
wd40 inside and out
mazdawg(mikey)   +1y
the problem is your truck. throw it away and start over.
badchicn (rick)   +1y
Bungie cords hold everything shut. or duct tape.
Check your door hinge and make sure it isn't worn out. Sometimes they get tweaked and the door latch doesn't line up with the striker anymore.
speedster93b   +1y
bailing wire, zip ties, and liquid nails. problem solved.
right. anyway, does your door sag when you open it? might need to adjust or get new hinges
badchicn (rick)   +1y
Chewing gum, silcone, fiberglass, that epoxy putty they sell on TV infomercials.
What he said ^^^
speedster93b   +1y
rick i didn't even notice you said the same thing i did in the post right above mine. lol i read the bungie cord part and skipped on.
what he said^^ ha ha
midnightmike   +1y
pull the latch out of it, and lube the crap out of it, work it good, be carefull not to break the little plastic clips
badchicn (rick)   +1y
No worries...I can be a smart ass at times, but I also try to be helpful.
