i only able to use high beams...the lows dont work at all..
could anyone tell me what the problem could be???
90-b22dawg [andrew]
head light switch could be bad or the bulbs
91b2200(cody)
^^ what he said. lol it can only be a few things wrong.
mazdawg(mikey)
your low beam fluid is low.
suicide
lol nice ^^^ might wanna check it...
immortal1 (linn)
Don't think this would be correct. If the low beam fluid was low, the high beam fluid would drain down and replenish it (seeing as the high beams are higher than the low beams). Typically this type of problem (low fluid) should only effect the high beams. Hope this helps Mikey.
As for the real problem - assuming both head lights have working low beam elements, another possible problem might be in the highbeam/lowbeam switch not working properly.
jmzcustomz (jeff)
Well this all depends now Linn. If...now lets just say if...he upgraded to the reverse polarity push pull headlights the fluid could actually be low. As there is a kool little resevoir that is used specifically for the high beams....after all we men love high beams!
On a serious note it could be a relay as well. If I am not mistaken the relay is three position. One side may be shot. Let us konw if you find out what the problem is.
