single cab rear glass Q ??
8
89dueceduece
will a rear solid glass window fit on a ex cab??
speedster93b's avatar
speedster93b
yes
8
89dueceduece
ok cool thanks man i thought it would i just dont want to take my truck apart and then have it not fit or something..do you know if its easy?
speedster93b
fits just as good as the one that's in there now.
8
89dueceduece
but is it a easy job?
tuckin20s
Yep, Todd and I took the solid window out of the standard cab and put it into the ex cab which had a slider in it. Took like 10 minutes. But you will want an extra person or two to help put it in!
8
89dueceduece
ok thats alot bro!
mazdadropped
I did it in my truck also !! i used two flat head screwdrivers to pop it in
dncr8203
Rope it in. Put some rope in the rubber molding in, were the frame of the truck would normally be, get the top or bottom started on the inside. have someone push on the outside of the window and slowly start pulling the rope. it will pull the seal under the frame and lock it in. takes a couple of minutes.
speedster93b
^ +1
