Mazda Exterior \  install rear window without help???
Mazda Exterior Mazda Tech
views 691
replies 3
slamdtaco   +1y
so I thought my 6 yr old daughter would be able to help me install my new solid rear window.....
I took out the slider and she isn't strong enough to help push to get the new one in
my wife wont be home for a few hours and it's already dark here
my only choice is to wait for her unless it's possible to install yourself
I'm using the string method around the seal and have done it on several other trucks with help
anyone have tricks to installing by yourself?
baddawg253   +1y
im a auto glass installer , the way i do em with small rope is i put a suction cup on the inside and center it pull alil on the cup then start your rope ( start the rope on the bottom center) once youve liped the rubber over to both corners its easy to reach around the back of the cab for a lil bit of pressure just work it around evenly on both sides working to the top . its alot easyer with someone in the bed but you can do it .
slamdtaco   +1y
I removed the extra cab windows and was able to press in on the window and pull the string at the same time.
new window installed.
YAY
speedster93b   +1y
good tip!!
