Mazda Exterior \  4x4 B2600 wheel/tire combo?
Mazda Exterior Mazda Tech
views 925
replies 4
maxda   +1y
Just wondering what some of you guys would recommend for a wheel and tire combo on my 4x4 B26?
As you know, the front hubs come out quite far making it tough to fit wheels on with center caps.
Sugestions?!
maxda   +1y
Would 6 bolt Nissan truck wheels () bolt up to my B26?
If yes, any mods need to be done?
elbine69   +1y
Those will bolt right up.
rufus   +1y
They should do fine, with most of the "stock" wheels that I have dealt with from Chevy, Nissan and Honda; I have had to perform a little router work on the inside to allow for the flange at the bottom of our hubs. It seems as though other manufacturers don't use the design concept. Also, keep your lugs, since our lugs are a little different than other SUVs and Trucks with a 6x5.5 setup.
maxda   +1y
Thanks for the help, guys!
The set of wheels/tires that I linked are gone. However, the same guy does have a set of the same wheels, but with 31x10.5 BFG ATs.
My question now is: will this combo clear the top A arm with the bigger, wider tire? Does anyone happen to have an idea of the offset on these particular Nissan wheels?
I'm going to look at them on Thursday, so any help/opinions/advice before then would be MUCH appreciated!
