Mazda Exterior \  Help! I need pics of billet installed
Mazda Exterior Mazda Tech
views 913
replies 9
following 6
sleepyspeed   +1y
okay I have cut my chrome grill center out for the one piece billet. do I drill out holes for the 4 post on the bottom?
I could just use some reassurance before I do something I shouldn't. I'm more nervous cutting up a $50 grill than anything I have ever done to the truck
90-b22dawg [andrew]   +1y
on my phantom grille it has holes drilled in the shell and rivets through the holes and supports of the phantom....
sleepyspeed   +1y
okay, I noticed that the rods on the bottom side have holes drilled in them, for maybe small screws to keep it located. I figured the top tabs would be some rivets. I just need to do a little more clean up to the hole in the shell and I think it will go together okay.
speedster93b   +1y
here's a question... why's it referred to as a billet grille?
sleepyspeed   +1y
good question...lol it's shiny that's all I know
and bump for any more input or pics
91extcab   +1y
its made from billet aluminum?
taken from wikipedia...
Billet (manufacturing)
From Wikipedia, the free encyclopedia
Billet refers to a cast semi finished product. It is also referred to as ingot, particularly for smaller sizes. A billet is typically cast to a rectangular, hexagonal or round cross section compatible with secondary processing, e.g. forging or milling. It can be produced either as coil or cut lengths. Ingots and billets are collectively known as bar stock.
below is taken from motorcyclecruiser.com
What's Billet?
Magic metal for custom motorcycles. By Evans Brafield.
Billet is a term tossed around frequently and loosely in cruiserland, but many people are confused about what billet actually is and why it's usually expensive. We recently heard of a proud cruiser owner who (when responding to a question about a bolt-on accessory) said, "That's not aluminum; that's billet." Clearly, some confusion exists here.
A quick trip to the dictionary tells us that a billet is simply a "bar of metal." Billets can be made of magnesium or steel or iron or lead, but because of its light weight and relatively low cost (compared with other light metals such as magnesium and titanium), aluminum works best for cruising applications. However, since pure aluminum is a fairly soft metal, the aluminum most billet accessories are machined from is actually an alloy of aluminum and other metals.
The folks at Jardine tell us that one of the most popular alloys found in motorcycle parts is 6061-T6 aluminum. In the 1950s the Aluminum Association adopted a four-digit numerical classification system for aluminum. The first digit, the six, states that this alloy contains aluminum, magnesium, and silicon; giving the alloy good formability, corrosion resistance, and strength. (If the first digit were a one, the metal would be more than 99 percent pure aluminum.) The zero means that special controls to limit particular impurities within the alloy were not incorporated (not a concern in motorcycle applications). The final two digits identify the particular alloy within the aluminum, magnesium, and silicon group. The -T6 designates aluminum alloys that have been thermally treated and artificially aged for additional hardness. So, to sum it all up: 6061-T6 aluminum is a light, strong, corrosion-resistant alloy that is ideally suited for motorcycling.
Since billet aluminum parts start their lives as blocks of aluminum, the finished parts must be carved from these blocks. Cobra's manufacturing engineer took us through the process of turning a boring block of aluminum into a part that is ready for the chromer or polisher. When Cobra develops a new part, all of the measurements are taken from the OE part that is being replaced or from where the new part will be mounted. The measurements are then turned into a 3-D wire-frame model on a computer. At this point, styling touches that influence the look and feel of the part can be previewed without cutting a single piece of aluminum. Once the part has been completely designed, the engineer creates the cutter tool list and the carving order that will result in the completed part (like a sculptor progressively removing aluminum from the billet). Cobra's new Valkyrie radiator covers shown above are a good example.
Yes, much of a piece of aluminum billet ends up in the recycling bin after a milling machine has extracted a part from within it. Unfortunately, aluminum chips return only pennies on the dollar of the cost of billet aluminum. That fact and the expensive, computer-controlled machinery required to precisely cut each part explain the higher cost of billet accessories. So, if billet parts are expensive to produce why not just die-cast the parts? Simply put, die-cast parts are made from aluminum poured into a mold, therefore it's difficult to achieve the uniform structure, strength, and flawless finish found in top-quality billet parts. Billet-look or billet-like parts are usually cast items dipped in chrome.
Now, when someone refers to a part as billet, you'll know what they think they're talking about.
speedster93b   +1y
lmao holy shit. i meant why are our mazda grilles referred to as billet, because they are not. they are several bars (a very loose defination of 'billet' in the sense we use it to describe parts) that are polished on one edge and riveted/screwed/welded together. <--- that loses the 'billet' right there.
now, if it were all machined out of one big ass hunk of aluminum, it'd be a billet...
hmm i guess its just something that bothers me. lol
sleepyspeed   +1y
yeah exactly, but they still call them billet. Maybe (polished on one edge and riveted/screwed/welded together grille) doesn't just sell itself like the term billet....lmao!!
toddluck   +1y
i drilled holes in the bottom of my shell and used small bolts to hold it
jmzcustomz (jeff)   +1y
Dale...CALL ME. I will explain how my old style phantom is held together. Idealy I feel it is superior because you can easily remove the billet section to polish it by hand. pm if you need my number.
