ok guys i am almost done with my cab and am about to start the bed....i cant seem to find a write up or any help on bd'ing a mazda bed....it doesnt seem to be hard i just dont know the right way to go about it....my bed floor is in half to start with except the two small pieces above where the fender wells used to be.....do i cut at the seems...do i do it like a yota bd or what....help me guys any advice, tips info etc. will be great....i can post pics later tonight....
baggedbmy93mazda
ok people i just want a few pointers....ok well i am going to go just do it....
i know someone will post something to help me .......
90-b22dawg [andrew]
wish i could help ya but i dont know anything about actually doing a body drop..... heres an idea.... look through the Project / Under Construction threads...... also paitents is a vertue, it hasn't been a full day since you posted...
baggedbmy93mazda
thanks and yeah i must b patient.....i looked in the threads a little but not all of them....im still searching.....
paparoach1983
WELL GO TO MINITRUCKINWEB.COM THEY HAVE DONE THIS TO A S10 BUT THE BASICS ARE STILL THERE I CANT FIND THE LINK BUT GO UNDER TECH AND/ OR TYPE IN SEARCH BODY DROP HOW TOO.
snoplow
we did my buddies s10 kind of going from the minitruckin build. that one was a litle ewasier because the way the box is designed. for my buddies truck we bacsically cut above the wheel well, kept a level line a cut. the front of the box was all spot welds so we drilled them out. the hardest part was the rear corners. we found we cut too far back and had to cut thru the bracing. but once we had it all seperated, we just lifted the bed floor up. used some steel stud wall screws to hold it in place. test fit and made adjustments. i built some spacers to make up for the difference. once we did it it wasnt really all that hard. just finding the point to cut and having the right measurements.
baggedbmy93mazda
thanks guys i just did it the easiest way since my bed floor is all hacked up....the po just chopped it up....i am looking to trade it....check my link i am loooking for a stock bed with a full floor....this bed would be great with a custom floor/bd......anyone interested???? let me know......
lomazda87
its easy it took about 4 hours a nite for 3 days to finish mine
skrapinsask
Well if you just raise you bed floor the only thing you have to do is space the mounts so it matches up with your cab. Here is a picture that droppedmydawg edited for me to understand where to make the cuts.
It's just MS paint but i still found it very helpful
