SHAVED DOOR HELP
SHAVED DOOR HELP
8
87b2grand
my passenger door will not open i am getting a clicking sound from the relay but no action any help is greatly apprecciated. Also any other advice or info anyone wants to throw at me is good. any vendor or shops in or around charlotte nc?
chafin's avatar
chafin
what kit did you use? if it's the one with the cable that you crimp it might have came undone. also check your wiring going to the door. make sure the ground is good and so on. a little more info would help though
8
87b2grand
thanks for the reply. I have pulled the solenoid out and checked everything its all good but just seems like ots not getting sny power to it at all.
speedster93b's avatar
speedster93b
my autoloc solenoids did the same thing after a few years. just got progressively worse pulling force. then finally they didn't have enough power to pull anymore. i contacted autoloc and got some new ones, but the truck's been off the road since then so i can't tell ya the new results.
splinter's avatar
splinter
If your using the magnetic silonoid, pull it throw in trash. Go to the junk. Yard and find a car with power licks and use them. On two different trucks I had magnetic ones and had problems everytime. I used gm door lock plungers and they never failed.
