Mazda Exterior \  removing gutters
removing gutters
Mazda Exterior Mazda Tech
views 1045
replies 4
snoplow   +1y
ok i just shaved my gutters off this weekend. easier than i thought. the a post is pretty much spot welded on except for about 2 inches from the top of the window. then from there the 2 halves are pinched and glued. no pics right now but will try to get some up before too much longer
chafin   +1y
i bet it looks good! im looking forward to the pics! hurry
snoplow   +1y
not too bad. by no means am i finished with it. be a few days for pics. computer went all goof y not too long ago and have to reload everything
mazdamandan   +1y
I did mine too a little while back, I found a lot of rust behind the seam sealer.
drivers side was bad I took out the spot welded steel strip.
Pass side was OK so I put a short sawzall blade on and carefully trimmed off the excess material, ie gutter
I neeed to file down the bottom edge so its not sharp. Looks good and there was no rust on this side.
mazdaman82   +1y
i shaved mine and rerounded the corner to look right and roll better
