Shaved door kit
Shaved door kit
ridinlow84
I wanted to put a shaved door kit on my truck. First ill be adding a door lock kit and alarm to the set up before I install the kit. My question tho is this, Where is a good place to put the door bottons? I will most likely wire the driver door to my remote but leave the passanger door to botton control. I will have a push bottom for both doors as a precaution. I just can't think where to put the buttons. Let me know if you have any suggestions.
sleepyspeed's avatar
sleepyspeed
If you run the solenoids on a relay as they should be. You can kick a relay with very little amperage.
What I did with mine is used micro push button momentary switches from radio shack. They fitted into the inner fender mounting holes on the lip of the metal fender. And there small enough no one can see them unless you on the ground.
I attached the wires to the switch and seal the wires with a little silicon and never had any issues. Another good spot would be under the bed rail were you would have to know were it was to find it.
