Mazda Exterior \  Removing bed?
Removing bed?
Mazda Exterior Mazda Tech
views 1261
replies 9
following 6
gregfarz78   +1y
I did a quick check I only saw a few bolts securing it to the frame is it that easy? Just checking b/c nothing has been that easy with this truck so far lol and I don't want to miss anything hidden.
mazdaman82   +1y
there is bolts inside the gas door, and iv seen on some trucks there is a ground wire, but not always there ans not always in the same place, and make sure you unplug the lights and pull the wires out of the bed
beatmymini   +1y
other than the filler neck there are 2 bolts in the front of the bed and 4 in the back
mazdaman82   +1y
wow you only had 6 bolts? mine had 8, 4 front and 4 rear on a std cab and bed...hell my long bed had 6 also...wtf...lol... but ya what he said^^^^^
gregfarz78   +1y
Nice doesnt sound too hard, now if the bolts aren't rusted to hell is a different story
mazdaman82   +1y
1/2 drive i beleave its a 17mm and a impact...
bagged89mazda   +1y
soak the bolts with penitraiting spray and let it sit a bit . who knows maybe you'll get lucky and someone had removed the bed before there for removing bed bolts could be easy
beatmymini   +1y
yeah just spray it down and let it sit over night then use and impact and you will get those bolts out in no time.
briandahawaiian   +1y
and if you don't have an impact gun, u could always use a long a$$ pipe for leverage. das how i did mine.
will   +1y
Should be 6 bolts, 2 front 4 back. Remove Tail lights, and other wiring. Make sure you unbolt your gasoline also. Buy new bolts n nuts when you put it back together, i just re-took mine off today since im looking for a 4x4 bed or a new 2x4 and ill make flairs my sefl
