Mazda Exterior \  Wheel fitment questions
Mazda Exterior Mazda Tech
views 964
replies 5
jibee   +1y
This is short and sweet. Will a 20 x 8.5 with a +31mm offset fit on a B2200 with 2wd sheetmetal? Thanks guys.
bagdb2200   +1y
I don't think they will. They stick out a 1/2" more than 17" Eskies/Denalis and with those the tire will hit the bedside when layed out.
thafox   +1y
i had the same question, but im running stock sus at the moment, there shouldnt be a problem right? and the offset and size im assuming is for the chevy 20's right?
hunterw   +1y
they will def. NOT fit in the rear. they scrape my 4x4 sheetmetal. they might fit up front if either you try and camber the front some OR shave a few mm off the mounting pad. but im not sure honestly up front. they fit 4x4 sheetmetal with very little camber. BUT will not fit with a body drop
thafox   +1y
how about stock 2wd body though? still have to trim the inside of the fender a bit up front?
bagdb2200   +1y
You mean your truck's not lowered or anything? If that's the case you should be able to run them. You'll have that nice flush look the stanced guys like too.
