Mazda Exterior \  stepside bed?
stepside bed?
Mazda Exterior Mazda Tech
views 1608
replies 7
following 5
fitbmx180   +1y
what beds do you guys use for a step side? ranger?
v8mazda4ever   +1y
The ford ranger splash has the step side box I believe the 95 and up models
mazdaman82   +1y
yes the ranger bed is the one used more offen.. it fits better then most others... its what i used on mine befor wreakin and sellin.. i have pics of it but im not sure how to post from the gallery anymore.....i still have the bed where you live?... i did i lot of work to the bed to make it fit better then most guys do.. plus i rised the fenders to lay on 18s maybe 20s
fitbmx180   +1y
how much u want for the bed? i might take a road trip if the price is right.,. also can i see some pics? im in ontario.. im quite a ways from you but im willing to drive
koda6966   +1y
All 1993+ ranger beds are the same. Although the 1993-1997 ranger generations would match your body lines far better than a 1998-2000, and definately better than an 01+.
You don't need to worry about encountering a 1992 or older stepside Ranger. And if you do, BUY it.. they are extremly (as in 15 made) rare. They were known as the "Shadow" edition Ford Rangers and I have only seen 3 in my life. One was questionable as to whether it is a true shadow.
mazdaman_573   +1y
Hey would those beds work on an x cab or not,cuz I tnk it would look cool
koda6966   +1y
I would measure out your xcab and see what it comes out as compared to a stepside ranger. Or compare to a regular cab bseries.
Most older trucks kept the same size bed and extended the frame. It wasn't until the 2000's or so when they started making those retarded mini beds.
It should fit though. Like I said, take measurements before you commit and buy one. That way you don't end up having to resell. If you can set it on there just to mock it up and make sure you like it.
mazdaman82   +1y
not right off it wont fit... you would have to move the axle back as the excab truck the axle sets more forword then the stdcab trucks.. i have one done already.. and i plan on the next truck being an excab so i can do this to it
