RCI Fuel Cell
RCI Fuel Cell
mazdadropped
Hey guys i have a 17 gallon RCI 2171A Fuel Cell (17"X30"X7")
Its 0 - 90 ohm
and i believe # 8 an male for return/pickup and rollover vent
would this give me an accuarate readin on the stock mazda guages and any ideas where to purchase these fittings for the lines (preferably a place youve ordered from and can be trusted)
bagdb2200
I haven't found a trustworthy source that states the ohm ratings on our fuel gauges, but it's definitely not 0-90. For the fittings, I ordered all the An stainless lines and fittings from Summit Racing.
mazdadropped
Also is there different types of fittings or just 3 of the same will work as long as they are 8 an , no pressure adaptors ect. ?? and what size fuel lines will i need to run same as a stock b2200 or no?
MJ
mr. jaun durfle
I've heard that it will make your stock gas gauge read the opposite, so if you have a full tank it will read empty. I don't have a RCI tank yet so I can't say for sure that is how it is, but the research I have done said it reads opposite.
mazdachik's avatar
mazdachik
Just put a RCI tank in mine and the gas guage does read opposite. But other then that it reads fairly accurate.
mazdadropped
i ordered all the fittings and steel braided lines. do i need a external fuel pump?? if so what kind and where can i get it . also how did u run the fuel lines to the ones near the engine 8 an - stock is big difference
oo7bob's avatar
oo7bob
-8an is a half inch. an fittings are all 16th's. your stock line is probably more like 1/4" - 3/8"
mazdadropped
ok thanks would i need to run a external fuel pump? i dont think the cell comes with a internal one
oo7bob's avatar
oo7bob
that fuel cell should not include one.
carb engines have a mechanical fuel pump on the block. i do not know where the pump is on an injected engine.
when you removed the old tank, was there one wire on the tank? that would give you a clue that there is no pump in there, and you will not need a new one.
was there 3 or 4 wires?, its in there. you need to buy one
