How much paint would I need to paint my truck. I plan on painting it flat white. Like Hot Rod Flatz or a brand like that. Thanks.
A Gallon should do it. You plan on sealing it too right? You'll also need some reducer most likely. I've never worked with Hot Rod Flatz but most paints need reducer.
johnnydigits
HotRod Flatz comes in 1 gallon kits. Its a 3 part kit and the one gallon kit is enough to paint your mazda twice.
E
exdxgxe
Thanks guys. I'll keep that in mind.
baddawg253
usually...two quarts paint will give you a gallon sprayable after harner and reducer..if its laqure itll give ya less so ya a gal of lac. will be more than enuff...youll have touch up ..
