Mazda Exterior \  Body Droppin ??
Body Droppin ??
Mazda Exterior Mazda Tech
views 897
replies 7
jealousonezenvy   +1y
I have a stdcab 89 mazda b2200. It has a 2 piece driveline. So when i cut the cab will i have to raise the tranny tunnel? The Bed will be easiest. The front should be no problem. Im gonna tub this also while i have it apart. My truck has a blowthrough also made from a jobox welded to my cab...
thermus   +1y
Pics or it didn't happen!!!! :mrgreen::mrgreen::mrgreen:
baha   +1y
If you are doing it traditional style you shouldn't have to cut it much but you may have to cut a section in the rear part of the cab for the drive shaft.
jealousonezenvy   +1y
even if its a 2 piece drive shaft?
baha   +1y
Sorry I misread your first post, if you lay full frame right now and you're not getting bigger wheels or tires it should be fine.
jealousonezenvy   +1y
yea im gettin 20s or 22s.... maybe i can just weld the bottom floor pan to the jobox after ic ut the stuff needed
mymmeryloss   +1y
No u dont need to...
jealousonezenvy   +1y
alright im gonna get some pics up later tonight so you all can see what im workin with.
