Truck bed dimensions - will factory truck bed liner fit '84?
roflwaffle
Was at pick n pull again today, found an 84 with some parts i need but couldn't fit in my car.
Noticed a later b2000 had the factory truck bed liner in great shape.. seeing as how the place wants only a few bucks for it, I figured I'd see if it would fit my truck..
The '84 is
86 long
57 wide
16 high
Anyone help me out with the dimensions on truck bed dimensions for a 1996 and for a 1987 (normal beds)?
I do a lot of moving of crap with my current truck, so a liner would help keep some of the junk off my bed.. I guess same goes for compatibility with truck caps, would be good to know if they'd fit (but i can just measure those methinks, but easier for searching online)
chaserjohndoe's avatar
chaserjohndoe
I currently have a tonneau cover from a 98 Tacoma on my 90 B22 and also have a topper for it from a 90 Toy truck. The beds had very similar dimensions. Some get ones from Rangers to fit but don't quite look right (imo). Just measure and see if its the same.
roflwaffle
Thanks, I guess I do need to go up there anyway to pick up the window glass. I was going to try to see if it would fit in my car but I might as well bring the truck anyway. I'm fearing that the wheel wells will be different or i'll miss something in getting it to fit right.
cant bring the b to check fitment in the parking lot as it's not yet roadworthy yet
dan woodland's avatar
dan woodland
Curious, where are you that you are finding so many early 80s Bs?
roflwaffle
Seattle.
One yard had a 78 and an 81, bout an hour away. Many same parts, interiors totally different. Engines slightly different, but many parts interchange. they were mostly picked over, at least for parts I needed. Another had an 82, which is pretty much exact, except for some little stuff, like the exhaust shield is different, and probably some stuff i didnt notice. That yard an hour away in a different direction. But, it has only been on the lot for 2 days, so I got pretty much first pick on the stuff.. lucky me.
Anyway, now I think I've picked over all the ones within a 100 mile radius. There's a few down in oregon, but I'm not sure I have anything I need worth the drive. Mostly went to pick up trim and interior bits and parts in better shape..
Anyway, I measured my truck and went to look at the factory truck bed. It looked pretty close, but hard to figure if the wheel wells would fit, so i carried it half way across the yard and plopped it in the 82 (a long bed, but works for what i needed to test). And... no.. the wheel wells are different enough it wouldn't go in. Pity as it was a super nice factory bed liner. At least it wasn't a wasted trip.
chaserjohndoe
the 86-93 parts aren't going to fit the pre 85 mazda/courier clones. nothing is the same not even the engines. I didn't notice that sorry. toppers and covers should still work though.
roflwaffle
I've heard the heads are the same, but I can't verify.
I still check out the later ones anyway since I'm there. I did grab a lug wrench off one, as the jacks/wrench are the same I'm guessing wheel lug pattern is same as well, though the yards always pull the wheels here, not sure where they end up. Also grabbed a gas release knob, it fit, but not well. Some parts may work in a pinch.. might see if i can get some shiney badges off a later one too, even if holes don't line up, you can obviously make it work.
I'm wondering if i can grab a bench from a later year, though i dont think they continued to make tan interiors.. but probably easier to find one in better shape.
i figured the truck beds might be same dimensions.. I mean, a datsun pickup has same bed dimensions as mine, within a small amount, and wheel wells line up, so i was hopeful a later mazda would be same. anyway, bed didn't fit, so :/
chaserjohndoe
wheels are swappable. they did make tan interiors in the 86-93's. other than that its a very select bit of parts that will fit. the heads are different, exhaust and intake are on opposite sides. almost bought an 82 with a bent frame and had the trucks side by side.
