Making corner markers into blinkers???
civic_boy_93@hotmail.com's avatar
low_life77's avatar
low_life77
I have searched the site in several areas and can't find a how to on making the corner markers into blinkers. I know it has been done by several of you. I was going to just splice the wires from the corner markers to the blinkers in the bumper but I'm not sure if that's the right way to do it and if it is which wires go where? Any help would be great. And as always thanks!
Cusser's avatar
Cusser
Sometimes they work, sometimes they don't work.
That's the old blonde joke about checking the turn signals !!! Be patient, someone here has already done this conversion, or ask also at mazdatrucking.com
dan woodland's avatar
dan woodland
Did you see this?
low_life77's avatar
low_life77
Thanks Dan! No I didn't come across that and this is what I was looking for. Seems easy and cheap, and looks factory and that's what I was going for
dan woodland
here, found more....
g_e_0_f_f
I just cut the plug off the corner light and soldered on the connector of the turn signal
low_life77's avatar
low_life77
Okay that makes sense kind of what I was thinking of doing but wasn't sure if it would work. So you left the original light socket in the side marker and soldered on the connector from the turn signal and then plugged it into the harness plug for the original turn signal or what?
g_e_0_f_f
Yup
