Mazda Exterior \  8.8 ford rear end swap?
Mazda Exterior Mazda Tech
views 3428
replies 8
following 2
jonnyboy303   +1y
hey guys has anyone done or considered doing a mustang or ranger 8.8 rear end? would it fit? and what would it take to work? lmk guys im interested on swapping for a five lug and stronger rear end cause im doing a 302 swap and not having any luck on used b2600i axles.
mazdizzle   +1y
I just put an explorer 8.8 under my truck. Had to narrow the drivers side 3 inches to center the pumpkin. It's about 1 7/8 shorter than the stock mazda axle.
jonnyboy303   +1y
How'd you do that? And did it bolt up for the most part?
mazdizzle   +1y
Nothing just bolts up fabrication is part of the fun in owning these trucks. Mine is bagged so I have a 4 link in the rear. Had to have a custom drive shaft made. Used the Lokar ec-81fu kit for the e brake cables. If you have extended cab you will have to order a longer inner cable for the passenger side.
jonnyboy303   +1y
True that. Do u have a build thread for your truck and rear end?
mazdizzle   +1y
I have one on here and on mazdatrucking
jonnyboy303   +1y
Can u post the link plz?
mazdizzle   +1y
It's in the member projects section on here. If you look you will find it in like 2 seconds
jonnyboy303   +1y
Ok cool thanks mazdizzle!
