Replacing bench W buckets
joeyaces
I was just wondering if anyone knows of buckets that would bolt into the bench brackets I currently have. (91' B2200 reg-cab) Is it hard to make brackets for buckets?(can you buy them?) Im not a machinist or anything close but I have a few friends that might be able to make something fairly simple.
midnightmike's avatar
midnightmike
im pretty sure that the factory seats will bolt right in except for one, ill take a look tomorrow
mark
yea, the xcabs come with buckets...Blare on here has em on his and like mike said, not all the bolts bolt in..but just drill a hole and plate the underside with a 1/4inch stock and you should be set
blare
ya all of mine went in except for my driver bucket. the inner rear bolt to the seat does not have a threaded hole. I m gonna just run a grade 8 bolt through to a piece of 1/4 that ill weld to a cross member down there (Mark's idea) or just an oversized dock washer (my idea)
