Hooking up your switches to your door popper control
juggalo_joker2003@yahoo.com's avatar
slammed83mazda's avatar
slammed83mazda
This is similar to the alarm topic, which helped me a bit thanks.
Well my topic is similar instead i want to wire my other 2 channels i have available that will raise the front of my truck and the rear, i tryed it but it just doesnt get the power
so i was thinking would i tire a wire from constant 12V to the front fills in both corners and do the exact same for the dumps and run the fills with constant power to one channel of the remote and the dumps to the other channel
any suggestions?
So you wired the channel wire to the power of the valve?, try holding down the button it should get enough power valves don't require alot, check your grounds.
you could also use a relay
slammed83mazda
like on a regular 10 switchbox, i was thinking this way could work, tap into the constant 12volts going into the front valves to lift and then running those wires together into one channel.......
and your saying this wiring layout should work?
ooh I see so you tapped it into the switch box, Theres so many wires in those things lol, Try running it directly to the valve because if your tapping into that wire depending on which one you might be getting the one before the switch it self, so you would have to hold the switch down and press the button for your valve to get power that way
slammed83mazda
so my fill wires thats going to my valves you saying tie those 2 together and run it into one channel and do the same for the dumps
carolinasled
you will need to use a 1-12v/30amp relay per valve on each corner up and down 8-total.
