Mazda Audio \  Speedo and Odometer not working
Mazda Audio Mazda Tech
views 1105
replies 5
thetornado   +1y
I swapped in a new Dash bezel today and everything works on it except the speedo and odometer...
the tach, gas, heat, digital clock, and all lights working.
when i pulled the cable out of the dash the little pin was still sticking in the dash rather than in the cable... so i had to pull it out, and put it back in cable. do you think that is broke or any other ideas for solutions?
mazdizzle   +1y
I'm guessing you switched to a cluster with a tach? Sounds like you might have a broken cable. When I put a tach cluster in mine the cable broke for some reason. I guess they don't like being messed with.
thetornado   +1y
did you replace it or what?
mazdizzle   +1y
Yep I went to the salvage yard and got another one
thetornado   +1y
sweet. i have a parts truck, so ill have to pull that one off.
so how hard is it to replace?
and where does it get attached to?
baggedb22   +1y
It gets attached to the side of the tranny, if u get under there u'll deff be able to find it just follow the cable from the back of the cluster down..
