help withh bucket seats ???
mazdabon2nd
i have a pair of bucket seats to replace my bench with does ne one have mounts for mazda bucket seat or ne ideea how ot make them ?? b,c i have the 2 mounts with the bench but i need 4
rutter0907
should be able to find some bucket seat tracks at a local junk yard. what kind of seats do you have to install?
mazdabon2nd
i have no clue i got them from a friend
FN
f n lo
your should be able to make up some mounts, i drilled thru the floor and tapped it and i was fine.... use your head, its not hard if you tak eyour time, ....
mazdawgydawg's avatar
mazdawgydawg
i couldent tell u how the brackets were made but i have mx-6 seats that bolt straight into a mazda but its true if u set ur mind too it u can get it done. btw i have a set of bucket seats have 3 good rails and 1 busted one there stock but i dont know how good they are email me if u want them ill look at them and get pictures
slammedmini469
just build some mounts
i did it for my old mazda, and it was FAR from a bolt in deal because i used 88 escort seats and sliders (which have a flat floor....)
at first i just made some tabs and bolted them to the stock escort brackets, but it made the seats sit up WAY to high (could barely get my legs under the steering wheel, im a pretty big guy)
so then i went to the local hardware store and got some 1.5" wide x 1/8" thick steel and made some brackets that bolted to the front, then bent to go right over the top of the "hump" that the front brackets bolt to, then striaght back to the rear mounts with a slight curve so it sat flat on the floor.
then i cut the old brackets off the escort sliders, bolted my new ones on, and mounted my seats which were now VERY low...but i liked it!
