which type of seats fit on a 87 b2000 ext cab with minor mod
8
87lowrider
does any know which type of seats fit on a 87 b2000 ext cab with minor moding and not really important but....how would you change the door panels or redo them in vinyl
2fine89's avatar
2fine89
90'ish 626 - front buckets bolt right in - comfy too.
As for the door panels - you need to remove the panel and either recover the stock board if they aren't to warped and wrecked - which they most likely will be. You can make new panels with "masonite" from local hardware stores. trace your old panel out on the new board - including the clip holes - cut it out - and recover with fabric of your choice. contact cement the panel and the fabric - lay on panel, wrap around back fasten with VERY short staples. Cut out holes and done.
8
87lowrider
sound easy ......yeah........easy......i goin to try it al right thanks....
8
87lowrider
wheres a good place to get vinyl? of wat ever fabric for the door panel?
slammed83mazda's avatar
slammed83mazda
your local carpet shop, if they dont have it im sure they can order it for you.
alan
you can get vinyl at craft stores, or walmart. look in the sewing and material section..Kinda feels weird. But it'll turn out nice!
