lights messed up
fanninator@yahoo.com's avatar
lights messed up
fanninator's avatar
fanninator
ok my electrical is messed up like crazy. this is what does what doesnt work.
-corner lights
-tail lights
-brake lights
-pass. turn signal in back and both up front
so thats that. any help would be awesome -bf
fanninator's avatar
fanninator
oh yeah my speedometer doesnt work (just put a new cable on like 5 miles ago) and my dash lights are out
thetornado's avatar
thetornado
so have you been doing any work or did this all just go out?
first thing i would check is all ur fuses...
fanninator's avatar
fanninator
well i have just got done w/ bodywork n such but its been settin in the shop but before it went it it didnt work. i have checked the fuses but im gona go check them again then start checkin my speedocable....but if my tach works y dont my speedo? weird stuff!
thetornado's avatar
thetornado
well ur tach is electronic. ur speedo will not work if the cable is not hooked in right. make sure ur cable is good. even though its plugged in, desnt mean its good. spin the end that twist in the tranny and watch to see if the opposite end is spinning.
drpdmazda
check the main wire harness that goes back to the lights, it runs down your drivers side under the kick panels, i accidentally drilled thru mine once and all my tail light functions went out, and as dumb as it sounds check the bulbs if for some reason you had a massive power surge it could have screwed all your lights
madmazda
^^^^^True, check your wiring....i would...
