Installing back glass
zshaver05@hotmail.com's avatar
drptndrgn's avatar
drptndrgn
How hard is it to remove my rear slider and put in a solid?? Im gettin it tomorrow and need some quick info.. Thanks
drptndrgn's avatar
drptndrgn
No one with any help?? Maybe its just to late tonite..
blazerpimp's avatar
blazerpimp
like the other back glass thread, it was mentioned that it would be ALOT easier to take out and put back in with a friend. You just need to relieve the seals from the body witha screw driver, and push out on the window...as far as install, you just need to reverse the process working the seal back into place.
b224u2nv's avatar
b224u2nv
it is really easy....i did it when i first got my truck..took about 40 minutes to do it by myself...
drptndrgn's avatar
drptndrgn
k cool thanks guys.. i was just wondering if there was anything tricky I should know about.
pont's avatar
pont
get some small string that will fit in the grove of the rubber seal soap it up or LUBE it up and stick the string in the grove then get a friend to hold the glass in place as you slowly pull the string from the inside of the truck to let the seal seat right
