Mazda Audio \  Power Cap Install...
Mazda Audio Mazda Tech
views 819
replies 2
following 2
madmazda   +1y
Hey guys, just wondering how i go about properly installing a digital Power cap...never installed one before, and i'd just like to know how...without blowing fuses over and over. Thanks!
drpdmazda   +1y
there are two ways that i know of that you can do it, i will try to diagram it, and post a pic, its the best i could do with ms apint, basically on the first you would get a 3 way distro block, go from the main battery to the block, then back to the amp, and run a wire from the positive side of hte cap to the distro block, still drawing power from the cap, make sure to ground all amps and cap in the same spot, to prevent ground loop, the second drawing you just go from the battery to the positive of the cap, then from positive on the cap to the positive on the amp, running the cap inline, and still grounding everything in the same spot, hope this helps you out a little bit, also make sure you use the same size power wire and ground wire, and remove the fuse before hooking up the cap
madmazda   +1y
Yea?
