Mazda Audio \  speedo, fuel, temp gauges dont work
Mazda Audio Mazda Tech
views 852
replies 7
following 6
boon   +1y
these dont work on my truck, i cant accum milage either... any idea wtf i gotta do to get these to work or why none of it is? they light up still...just nothin works
madmazda   +1y
Fuse?
midnightmike   +1y
check the METER fuse in the fuse box, but the speedo is a cable that should work unless its unplugged
thetornado   +1y
yaya, those are all electric except for your speedo. but if they all dont work maybe you just need to pullit out and make sure everything is plugged in properly.
have you ever had pulled it out before? theres 3 wiring harnesses and then the speedo cable.
boon   +1y
i think tomorrow i will pull it apart and see what i can find... and also check the fuse... thanks guys
solow93 (ryan)   +1y
do the lights work fine
boon   +1y
ya they work fine
mazdamandan   +1y
maybe its pulled forward just enough to pul speedo cable out and some of the wires are not all the way in ?
I've done extensive interior work and played with the cluster a
