heater does not work in my 88 mazda
F
F
freakinmaz
i'm havin a trouble with my heater in my truck! the cold air work's but not the heat! and on the dash the temp gage does not work sometime's! i replaced the sensor for the temp! but not luck on that! the blower still work's!
need some help!
F
freakinmaz
it's a 88 b2200!
crazymikey's avatar
crazymikey
Hmmm....I would try replacing your thermostat. If it's not functioning,your truck will either run cold all the time,hence not giving you heat,or it will overheat.
I have a similar problem,where my truck only blows heat. However,I did just put my dash back in,so there's a good chance I may have installed something incorrectly.
b22wala
Thermo for sure also make sure the core is not bypassed
lil big red's avatar
lil big red
Check the air/heater selector in your dash, it might of broke. When i got my truck I had no heat so I replaced my heater core and put everything back in there, and had same problem. I check that and replaced it for 20 bucks from ebay. So i would check the cold air/heater selector 1st.
