Mazda Audio \  warning lights
warning lights
Mazda Audio Mazda Tech
views 1393
replies 12
following 9
carolinasled   +1y
2 warning lights stay on while ignition is on.
brake light and anti lockin brake light.
any help to reset these. other than pullin ground from battery.
thanks
gravity5   +1y
Find out what the problem is, thats where I'd start. Is the brake fluid full, and when you stomp on the brakes does the abs work or does the truck just slide( rear abs only I believe )
carolinasled   +1y
everythings good. the lady who owned it before me said it was goin on for a long time. she kept this thing in very good condition. no low fluids and it doesnt slide or jerk or bounce or anything. its just the lights or getting on my nerves. i know if you pull the park brake the light will come on but it's being released all the way everytime....?????......
hocbj23   +1y
There is an ABS sensor on the passenger side rear just behind the axle.Sometimes it gets corroded up and causes the two lites to come on.Check it.ALso,MAzdas are pretty sensitive about brake reservior being full.There is also a sensor on the side of the brake reservoir,be sure it is plugged in.BJ
carolinasled   +1y
thanks i'll check them, also if its corroded bad behing the axle what do i need to do with it???
fanninator   +1y
quick dry electronic cleaner. it should be about $6 for a 11oz can -bf
midnightmike   +1y
unplug the ABS computer under the drivers seat, the abs sucks anyways its only in the rear, i pulled it along time ago and never had a problem since
hocbj23   +1y
what the man said about electronics cleaner.Uncouple the connectors,spray real good with elec cleaner.It dries immediately.plug them back up and see if ur lites go out.Or do as MM says and unplug the ABS computer.Actually I like the rear ABS cause trucks are so lite in the ass they skid in slick conditions so ABS does work there.BJ
crazymikey   +1y
I had the same thing going on with my Rodeo
j4k3   +1y
I also have the same issue. I had my truck sitting for about 2 months and now my brake pedal goes almost all the way to the floor. When I checked it my fluid was a little past the minimum line and after I refilled it, I still don't have any real brake pressure. However, the brakes work if I almost put it to the floor.
