Mazda Audio \  buckets
buckets
Mazda Audio Mazda Tech
views 926
replies 5
twistedsmily   +1y
will stock x-cabs buckets just bolt in to a benched b2k or do you have to drill holes for them or what custum some brakets up
1lob2k   +1y
should just bolt in except for the four bolts in the middle
crazymikey   +1y
I had a bench in mine a I got buckets from an ext cab and they bolted right in. The other holes are there,they're just covered with black rubber plugs. Pull them out,and the seats will bolt right in. Make sure you take the bolts from the truck you get the seats from.
twistedsmily   +1y
I was thinking they would but wasnt sure (need to find stock x-cab seats now)
Thax for the help bros
1lob2k   +1y
I have a set of buckets out of a standard cab I'll sell
twistedsmily   +1y
I found a good set out of a x-cab at a junk yard that i might be able to get for cheap but if not were are you located Im in lower Alabama
