steering wheel??
steering wheel??
mazda23
could some one take a pic of their steering wheel of or describe it to me because i have a steering wheel lying around and dont want the stock one. i want to know if it will fit or if i can make a adapter to make it fit
sudkrap's avatar
sudkrap
Grant makes a lot of adapters for steering wheels, is the one you want an aftermarket, or from a different vehicle?
sudkrap's avatar
sudkrap
the grant kit is pt# 3597 for the 86-93 b's
mazda23
its an aftermarket one but there may be the slightest chance it could work with out an adapter??? i just want to see a pic or a description.
sudkrap's avatar
sudkrap
Basically your steering wheel fits onto a splined shaft.. about 5/8" ish diameter shaft.. then a locknut threads on and holds the wheel to the shaft..
sudkrap's avatar
sudkrap
Sorry bad pic, i hope this one is better...
crazymikey's avatar
crazymikey
Grant install kit is like $35 and you can get it at Canadian Tire,and it'll take you no more than 10 mins to install.
I put a Grant steering wheel in my truck because I hated the awful 2 spoke steering wheel that was bigger than my rims.
mazdatweaker
There are a couple of screws holding the horn pad on. Remove them, the horn pad falls off in your hand. There is nut holding the steering wheel on. Loosen it. While you have the steering wheel centered in a dead-ahead position, bang on the back sides of the wheel where you hold on to it. That will loosen it on the shaft it attaches to. Take the nut off the rest of the way. Remove the wheel. Take your other steering wheel and see if it fits.
In the three minutes I have taken to describe this process, and the four minutes it will take you to TRY this process, you will answer every single question you are asking here.
mazda23
ok thanks
tonka's avatar
tonka
does that kit have the adapter? I dont see it in the picture. And does Canadian tire have everything you need except the steering wheel?
