Deck wireing?
dj@unlimitedkustoms.com's avatar
Deck wireing?
mazdawgydawg's avatar
mazdawgydawg
Can anyone help me with a wireing diagram for an aftermarket deck in a mazda? i cant seam to figure out what wires are what thanks,
-Dj
fanninator's avatar
fanninator
i can attempt a diagram but im not 100% sure i can. but you still got a speedo cable? i broke another one....
gravity5's avatar
gravity5
the wires for the truck or the deck. If its for the truck do yourself a favor and buy an adapter harness for 15 bucks.
fanninator's avatar
fanninator
you still got a speedo cable? i broke another one....i can help you wire t if you want.
YELLOW - battery - run a wire directly from your battery
RED - acc - goes to your fuse box (i used the wiper hole so that the cd player would go off when the trucks shut off and would come on when it was started)
BLACK - ground - i used the radio bezels metal frame piece, just one of those screws.
BLUE - remote - goes to the amp, if you choose to have a sub/amp
ok if you hold the wiring harness toward you as if it were installed and on the cd player, you will see 4 pairs of colored wires. on an older pioneer i have the harness is like this.
ground rem white grey
battery acc green purple
white - front left speaker
grey - front right speaker
green - rear leaf speaker
purple - rar right speaker
oh and if your running an amp, you will need to run set of rca wires from the sub out or one of the rca preouts (should have at least 2 pairs of red/white holes) just plug them in and then run them to the amp. hope i helped, and if you need anything else just ask. -bf
carolinasled
1986-89 Mazda B2000/B2200 Stereo Information:
Constant 12V+ Blue/Red
Switched 12V+ Red/Black
Ground n/a
Illumination Blue/White
Dimmer n/a
Antenna Right Front
Front Speakers 4" Dash
Left Front (+) Blue/Red
Left Front (-) Blue/Yellow
Right Front (+) Blue
Right Front (-) Blue/White
Rear Speakers 4" Side Panels
Left Rear (+) Blue/Red
Left Rear (-) Blue/Green
Right Rear (+) Blue/White
Right Rear (-) Blue/Green
1990-93 Mazda B2000/B2200 Stereo Information:
Ground n/a
Dimmer n/a
Antenna Right Front
Rear Speakers 4" Rear Corners
1986-89 Mazda B2000/B2200 Cruise Information:
Constant 12V+ Black Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+ Black/Red Ignition Switch Harness
Ground Use Chassis Near Cruise Control Module
Hot Side of Brake n/a
VSS Wire n/a
Pulses Per Mile 8000 PPM
Notes: Vehicles with Manual Transmission require Clutch Switch. Some vehicles may require a speed signal generator and/or other parts/adapters not listed above. Rostra® Cruise module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
1990-93 Mazda B2000/B2200 Cruise Information :
Switched 12V+ Black/White Ignition Switch Harness
VSS Wire Green/Red 22 Pin Connector of ECM 5th Position left to right
Pulses Per Mile 4000 PPM
1986-89 Mazda B2000/B2200 Security Information:
Starter Black/Yellow Ignition Switch Harness
Ignition Black/Red Ignition Switch Harness
Trunk Pin n/a
Parking Lights Red/Black Light Switch
Hood Pin n/a
Factory Disarm n/a
Door Trigger Red/Yellow (-) Courtesy Light
Door Lock n/a
Door Unlock n/a
1990-93 Mazda B2000/B2200 Security Information:
Ignition Black/White Ignition Switch Harness
Trunk Pin n/a
Head Lamp Red/Black Switch
Hood Pin n/a
Factory Disarm n/a
Door Trigger Red/Yellow (-) Driver's Kick Panel
Door Lock n/a
Door Unlock n/a
sorry for it being so long. hope it helps.
madmazda
Its not hard, Test the Wires, you need Ground, Constant Power, Ignition, and then Front Left and Right (+),(-) and Rear Left and Right (+)(-) Speakers, And Remote. and We dont have Illumination or Power Antenna so you dont need to use those.
carolinasled
just grab a meter for the ign,const, and ground.
and a nine volt battery with harness for the speakers.
madmazda
These are the Mazda Truck colours and what they are, Write them down, and go and try, make sure to remove your (+) or (-) Battery terminal just to be safe, haha...Dont want no sparks flyin'...
MEM - Blue/Red
PWR - Blue/White
RF - Blue/Red (+)
RF - Blue/Yel (-)
LF - Blue (+)
LF - Blue/White (-)
RR - Blue/Red (+)
RR - Blue/Green (-)
LR - Blue/White (+)
LR - Blue/Green (-)
Need Any help, give me a shout on msn...Later
fanninator's avatar
fanninator
as far as an adaptor goes, i didnt need one because i ran all new wiring and ditched the entire stereo in the truck and bought all new stuff. my build is in the photo section in case you want some ideas or something. -bf
fanninator's avatar
fanninator
